4wd solenoid?
/ 4wd solenoid? #1
chugger172
Where is the four-wheel-drive solenoid located on a DK 40?
/ 4wd solenoid? #2
On my 2010 model the 4wd relay is under the steering wheel dash cover. And the solenoid itself is located on the transmission body. I have a picture in my service manual and ill try and attach it later today. Its out in the shop.
/ 4wd solenoid? #4
Ok, this gets a bit complicated, as i dont know year of your unit. But if its close to my 2010, the solenoid is attached to the modulator assembly on the hydraulic lever control unit. Ill also attach a link to another doscussion.
First off, there are fuses that control PTO Function.
There are relays under instrument column that control PTO Function. And the relays are the usual problem.
There is also a microswitch on some units to prevent pto engagement in mechanical driven units.
And finally the pto solenoid…which is uber expensive part.
First test the fuse. Those are labeled.
Heres the pto relay behind instrument panel, ill also incluse test procedure for relay
Heres the pto switch and microswitch data..
And finally, heres the info on the PTO Solenoid
/ 4wd solenoid? #5
Also, heres a link to a similar issue
/ 4wd solenoid?
Is the pto solenoid and the 4wd solenoid the same?
/ 4wd solenoid? #10
Let me find info on 4wd system. I guess im more tired than i thought
/ 4wd solenoid? #11
Ok, this is getting harder. So far i can only find offhand reference to 4x4 functions. Rough schematic points to 4wd solenoid as part #37. But i cant find any actual call out for it, or what it looks like. Im looking further. Also, heres the diagnostic for 4wd switch.
/ 4wd solenoid? #12
/ 4wd solenoid? #13
TIL [Today I learned] that some compact utility tractors have push-button 4WD
I figured they all just had this lever that you crammed the gears together
/ 4wd solenoid? #14
Ok, the book sucks in diagnosing 4wd solenoid, but it is part of the modulating valve assembly. Look at this diagram
2018 Howden 24 URAI-B Rotary Lobe Blower with Utility Trailer (A61572)
2018 Howden 24...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
UNUSED WOLVERINE 7' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2010 BOBCAT E80 EXCAVATOR (A64279)
2010 BOBCAT E80...
