4wd problem
/ 4wd problem #1
dogday
I have a 2006 DK40 with the manual shift 4wd. Push the lever down to engage the 4wd, pull the lever up to disengage. My problem is it has always been a little tough to disengage the 4wd but this time I used my tractor for about 8 hrs and I can not get the 4wd to disengage. I have tried different gears, speed, neutrals, reverse, forward and nothing seems to get it out. Any Ideas would be great.
/ 4wd problem #2
Try rocking your DK40 back and forth several feet using the clutch and shuttle while pulling up on the FWD lever. It usually disengages.
/ 4wd problem #3
Lift the front axel off of the ground with the F.E.L. It should easily shift out of 4 wheel drive. If it does not, then check your linkage. start pulling pins in the linkage to find out where it is binding at. I have had a few that were rusted up at the shaft that goes into the transmission. Some penetrating oil and a little working of the shift lever back and forth freed everything up.
/ 4wd problem #4
Many times the issue is where the shifter shaft goes through the case. Just spray a little penetrating oil where the shift shaft goes throughthe case and work it free. Then spray the same area with a little white lithium.
