4wd not engaging
   / 4wd not engaging #1
oneparsec
Hello everyone: have 40hp Mahindra and the 4wd won't engage when moving lever to 4wd. Any suggestions a to where to start looking. Thanks
   / 4wd not engaging #2
Try rock tractor...turning wheels back forth..tractor has front loader down pressure until front wheel off the ground.
   / 4wd not engaging #4
Any resistance on the lever? I would start by crawling under the tractor and check the linkages.
   / 4wd not engaging
Thank you for the suggestions. I'll check them out.
   / 4wd not engaging
No, lever moved but no engagement
   / 4wd not engaging
Broken roll pin? If lever is moving and not engaging.
I looked under the tractor. Linkage attached. Should i unhook the linkage and try turning the shift manually. With tractor off of course.
   / 4wd not engaging #8
If your linkage is moving the shaft like it is designed to, I would next uncover your driveshaft and gearbox output shaft and examine -Some simple testing here will allow you to determine if the issue is in the gearbox vs driveshaft vs front diff/axle
   / 4wd not engaging
Okay, good idea. thank you
   / 4wd not engaging #10
Use the bucket to lift the front end, then see if it engages.
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2013 Nissan Pathfinder (A50324)
2013 Nissan...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2011 FORD F-650 (A50854)
2011 FORD F-650...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
