499 haybine??
/ 499 haybine?? #1
ZekeIH4210
4210 Case IH
Question for anyone out there and I can’t seem to find it online. I am new to using a 499 haybine just had a sickle cutter before but ran a1411 discbine when I still lived on the family farm.
Question is are the 2 cutting bars independent or do they get bolted together in the middle? Ran fine for 40 acres now it’s making a banging sound and the only thing I found so far is where the 2 bars meet they are not bolted together, but I don’t see any bolts missing either? Please help
/ 499 haybine?? #2
My 489 had one solid cutting bar that went from one side to the other. Perhaps your bar broke in two and that's the banging noise?
/ 499 haybine??
I know there is special bolts, nuts, and guards for the middle cause the auction I bought it at the farmer threw in a box of parts just for the middle of the haybine, but it’s hard to troubleshoot the noise on a hydraulic pump drive system on a 479 I would just turn the teeth arm by hand that doesn’t work on the 499.
/ 499 haybine?? #4
check each sickle bushing. One may be going on vacation.
/ 499 haybine?? #5
The Sickle Bars go opposite direction to reduce vibration, In/In, Out/Out
So yes a Bushing, or Guard Alignment where they meet in the middle.
/ 499 haybine??
Do they also get bolted together in the middle? I checked bushings, I also replaced 2 guards that were a little bit bent but still have the noise and were the two cutting bars meet they move a lot
/ 499 haybine??
Alright I will definitely double check all of those but is there anything that connects the two bars together? A shim that bolts the 2 bars together or something?
/ 499 haybine?? #8
No they reciprocate, but if I remember correctly the center sections and guards are special units for the overlap
These things were New when I was working on them back in the 80's
/ 499 haybine??
So sorry I didn’t get back on here right away. I broke my left ankle and foot and didn’t get back to the noise right away. Anyway one noise a loose guard in the middle section where the 2 bars overlap and the second noise I found was a roller starting to loose some rubber
PT Gravity Wagon (A64127)
PT Gravity Wagon...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
2025 SDlanch SDLD25 (A64127)
2025 SDlanch...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
