499 haybine??
/ 499 haybine?? #1
ZekeIH4210
4210 Case IH
Question for anyone out there and I can’t seem to find it online. I am new to using a 499 haybine just had a sickle cutter before but ran a1411 discbine when I still lived on the family farm.
Question is are the 2 cutting bars independent or do they get bolted together in the middle? Ran fine for 40 acres now it’s making a banging sound and the only thing I found so far is where the 2 bars meet they are not bolted together, but I don’t see any bolts missing either? Please help
/ 499 haybine?? #2
My 489 had one solid cutting bar that went from one side to the other. Perhaps your bar broke in two and that's the banging noise?
/ 499 haybine??
I know there is special bolts, nuts, and guards for the middle cause the auction I bought it at the farmer threw in a box of parts just for the middle of the haybine, but it’s hard to troubleshoot the noise on a hydraulic pump drive system on a 479 I would just turn the teeth arm by hand that doesn’t work on the 499.
/ 499 haybine?? #4
check each sickle bushing. One may be going on vacation.
/ 499 haybine?? #5
The Sickle Bars go opposite direction to reduce vibration, In/In, Out/Out
So yes a Bushing, or Guard Alignment where they meet in the middle.
/ 499 haybine??
Do they also get bolted together in the middle? I checked bushings, I also replaced 2 guards that were a little bit bent but still have the noise and were the two cutting bars meet they move a lot
/ 499 haybine??
Alright I will definitely double check all of those but is there anything that connects the two bars together? A shim that bolts the 2 bars together or something?
/ 499 haybine?? #8
No they reciprocate, but if I remember correctly the center sections and guards are special units for the overlap
These things were New when I was working on them back in the 80's
/ 499 haybine??
So sorry I didn’t get back on here right away. I broke my left ankle and foot and didn’t get back to the noise right away. Anyway one noise a loose guard in the middle section where the 2 bars overlap and the second noise I found was a roller starting to loose some rubber
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
John Deere 544C Wheel Loader (A65579)
John Deere 544C...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
ALUMINUM TOOLBOX (A64277)
ALUMINUM TOOLBOX...
