4835 vs tn70d
   / 4835 vs tn70d #1
tfedd
Northwest Ohio
Case IH JX95 MFD
Looking at 2 tractors, a 4835 with 3000+hrs($17250) and a tn70d with 1800 hrs.($23250) They are both equipped close to the same.(mfd,loader,cab,ect) My question which do you think is abetter deal? Is there any major differences between the two? I plan on using the tractor to cut rake and bale hay, along with plowing snow with a front mount plow. Thanks Todd
   / 4835 vs tn70d #2
The 4835 is a heavier tractor, more closely related to the TL than the TN. It is also a 4 cyl. vs 3 cyl. in the TN.
   / 4835 vs tn70d #3
The 4835 has a multiple disc wet PTO clutch. The 4835 is a flat deck tractor with much better visibility than the TN. If the 4835 has never had a new main clutch, it may be getting close to needing one. If the condition of these tractors is comparable, I'd probably swallow the extra 1200 hours, bank the $5K and buy the 4835.
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53472)
DeeZee Crossover...
1271 (A50490)
1271 (A50490)
8x12 Custom Built Greenhouse (A51573)
8x12 Custom Built...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
