48" or 60" Box Blade
/ 48" or 60" Box Blade #1
Fruitguy
Stafford, NY
Cub Cadet SC2400
I have a sc2400 and will be purchasing a box blade and thought I would go with a 48" to cover the wheels but some have suggested a 60". I would prefer to have the correct size even if it is smaller.
Was wondering what others are using or have used with a 4wd 24hp SCUT.
Thanks,
James
/ 48" or 60" Box Blade #2
The main thing is making sure it covers the wheel path (tracks), and the rest depends on what your going to be doing with it. I had a SCUT (13 hp) four wheel drive that I put a 5 foot boxblade behind. It worked fine for what I was doing with it, which was spreading dirt under a beach house that a hurricane had washed out the sand under. If I needed to dig dirt and rock, it would not have done nearly as well, but due to what I needed, it worked great. It really depends on your uses.
David from jax
/ 48" or 60" Box Blade #3
I have 26 hp BX2660 and run a 48". I pull a lot of rock and wouldn't want anything larger. If I were working clean gravel and dirt id go 60".
/ 48" or 60" Box Blade #4
I have used both on my BX2660 and prefer the 48" overall.
Thanks for the input. I think I am leaning towards the 48". I can always take a couple extra passes.
/ 48" or 60" Box Blade #6
I have a 32 HP JD 4x4 and I have a 5' seems to be a good fit, especially for working it hard /digging deep.
I think your wise leaning towards the 48", a box can get pretty heavy when worked hard, it would do you no good if you were just spinning your wheels.
For a rake I would go one size up at least, I have a 6' could probably go wider if just used for fine finish work.
JB
/ 48" or 60" Box Blade #7
I run a 60" behind my JD855. It works but I do run into occasions where it's too much to pull. It's all situationally dependent. Pulling gravel up the road I run with the blade full of material. I do so in 4WD. If I'm also ripping ground with the scarfers.... I will often find myself spinning my wheels.
Maybe I need a second blade?
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
John Deere Z997R (A60462)
John Deere Z997R...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
208320 (A58375)
208320 (A58375)
Case IH 950 Planter (A63688)
Case IH 950...
JOHN DEERE 5075E TRACTOR (A63291)
JOHN DEERE 5075E...
