48 Hoe
/ 48 Hoe #1
newaukum
Washington
JD 4310 MFWD eHydro and JD LX176 Lawn Mower
Who makes the 48 hoe for Deere?
/ 48 Hoe #3
I believe Ameriquip makes it for deere. The 48 B.H. is the same as the Pro 850 B.H. for the skid steers.
/ 48 Hoe #4
The 48 backhoe is made in Canada by John Deere at the McClellan Works.
The compact tractor loaders are made there also.
Mike
/ 48 Hoe #5
JDtech would you give me your opinion on the boom float question posed in post #198 below.
JD 48 hoe on 4610 & 4710's
Thanks in advance,
/ 48 Hoe #6
When I got my tractor the loader had a label that read Welland Works,, Canada, the backhoe said JD, Debuque Iowa. Of course, I could be wrong....
JD Locations
/ 48 Hoe #10
For the compacts that is true but the bigger tractors and tillage equipment deere makes most of their own.
/ 48 Hoe #11
I would bet that they actually completely make the hoe in iowa since that is where the ones off the 110 tlb come from and the loader for the 110 comes from ontario canada.
/ 48 Hoe #12
RockyRidge Mike,
You are right. Backhoes are made in Dubuque.
(This proves Mike's are normally right)
/forums/images/graemlins/grin.gif
Mike
/ 48 Hoe #13
The 48 Hoe and the 110 hoe are two comletley different units. When I was at the Augusta plant for training they told us the 47 & 48 hoes were made by Ameriquip for them, and that was why they were having so many problems with bad hoses and bent cylinders. Deere makes the 110 hoe.
Miscellaneous Mini Excavator Attachments (A61572)
Miscellaneous Mini...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
207277 (A52708)
207277 (A52708)
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2004 John Deere 8320 (A63688)
2004 John Deere...
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
