Backhoe 48 backhoe - cylinder leaking - need replacement
/ 48 backhoe - cylinder leaking - need replacement #1
gvw
Central mountains of Colorado
JD4700
One of the hyd cylinders on my 48 backhoe is leaking to the point I really need to consider replacing it - seems that there have been several postings as to the lousy quality of these cylinders and noting the point that apparently they cannot be repaired but must be replaced - therefore the question comes as to where do we obtain a "better" cylinder as I am not to excited about replacing with a JD part that would assumedly need replacing again in the near future.
/ 48 backhoe - cylinder leaking - need replacement #2
gvw,
</font><font color="blue" class="small">( seems that there have been several postings as to the lousy quality of these cylinders and noting the point that apparently they cannot be repaired but must be replaced )</font>
Why do you say that the cylinders cannot be repaired?
I just checked the JDParts website and it appears that all cylinders on the 48 backhoe have a complete set of components available for purchase. In addition to that, a good local hydraulics shop will likely stock or be able to obtain or manufacture any required parts.
I would think that it would be well worth your while to compare the cost of having a leaking cylinder repaired to the cost of a new cylinder.
I stand somewhat corrected - mine apparently can be rebuilt - evidently not all cylinders on the 48 backhoe were built the same way -- I was originally told that they could not be rebuilt and honestly had taken that information at face value. When I called another JD dealer - he advised that mine were the type that could be rebuilt - so will take them off and leave it for several days. Would do myself but apparently a special spanner wrench is required to remove the caps - they will do the labor for $50 so that will be the route to getting the cylinder fixed.
/ 48 backhoe - cylinder leaking - need replacement #4
gvw,
</font><font color="blue" class="small">( they will do the labor for $50 so that will be the route to getting the cylinder fixed )</font>
Glad it worked out for you! Sounds like you connected with a good dealer.
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
