Backhoe 48 backhoe - cylinder leaking - need replacement
/ 48 backhoe - cylinder leaking - need replacement #1
gvw
Central mountains of Colorado
JD4700
One of the hyd cylinders on my 48 backhoe is leaking to the point I really need to consider replacing it - seems that there have been several postings as to the lousy quality of these cylinders and noting the point that apparently they cannot be repaired but must be replaced - therefore the question comes as to where do we obtain a "better" cylinder as I am not to excited about replacing with a JD part that would assumedly need replacing again in the near future.
/ 48 backhoe - cylinder leaking - need replacement #2
gvw,
</font><font color="blue" class="small">( seems that there have been several postings as to the lousy quality of these cylinders and noting the point that apparently they cannot be repaired but must be replaced )</font>
Why do you say that the cylinders cannot be repaired?
I just checked the JDParts website and it appears that all cylinders on the 48 backhoe have a complete set of components available for purchase. In addition to that, a good local hydraulics shop will likely stock or be able to obtain or manufacture any required parts.
I would think that it would be well worth your while to compare the cost of having a leaking cylinder repaired to the cost of a new cylinder.
I stand somewhat corrected - mine apparently can be rebuilt - evidently not all cylinders on the 48 backhoe were built the same way -- I was originally told that they could not be rebuilt and honestly had taken that information at face value. When I called another JD dealer - he advised that mine were the type that could be rebuilt - so will take them off and leave it for several days. Would do myself but apparently a special spanner wrench is required to remove the caps - they will do the labor for $50 so that will be the route to getting the cylinder fixed.
/ 48 backhoe - cylinder leaking - need replacement #4
gvw,
</font><font color="blue" class="small">( they will do the labor for $50 so that will be the route to getting the cylinder fixed )</font>
Glad it worked out for you! Sounds like you connected with a good dealer.
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
New - Front mount rototiller
New - Front mount...
John Deere 6125R (A64126)
John Deere 6125R...
