475 Di early Models
/ 475 Di early Models #1
Schriever, Louisiana about 55 miles sw of New Orle
JD 5420, 445 Long
I have a 475 Di. It has a 3 cylinder engine. My question is online I find 475 Di with 4 cylinder engine why and when did they change to 4 cylinder engines?
I also found out that the PTO speed runs at different speeds according to high and low transmission settings instead of engine speed.
I like this little tractor I can work it all day on a cup full of fuel.
Thanks
/ 475 Di early Models #2
I don't know when they changed the 475 Di to the 4 cylinder motor, but I am curious if you have the same 3 cylinder motor that is in the later 350 Di. I have a 350 Di, and that is a strong tractor. I use it mainly for bush hogging and plowing a 3.5 ac field. You can't even tell that the 5' bush hog is behind you. It'll also run all day without a single compliant.
Regarding the PTO, you may want to get advice from a dealer or from Mahindra. With the 350 Di, you are not supposed to run the PTO in the high range.
/ 475 Di early Models #3
I have a manual for the 475DI, 485DI, and 575DI, dated August '98. It shows the 475 with a three cyl. engine. If they changed, it was after the manual was published. There is a PTO speed selector on the left side of tractor below the clutch pedal. It has a Hi, Lo, and neutral. All brush cutters are intended to run on the low setting, as are all PTO driven equipment (as far as I know). The lo PTO speed is 540 rpm@2058 engine rpm and hi PTO speed is 1000 rpm@ 2043 engine rpm. Hope this helps.
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
John Deere 350 Sickle Mower (A66408)
John Deere 350...
2025 Grapple Rake Mini Excavator Attachment (A64553)
2025 Grapple Rake...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
ASV RC-85 Skidsteer / Compact Track Loader (A66285)
ASV RC-85...
