474 cab dome light bulb replacement
/ 474 cab dome light bulb replacement #1
seacraft18
Want to swap out the cab dome light bulb with led. Not sure if the lense twists off or prays off.
it is so cheap, no matter what I try it feels like it is going to break. I am assuming it is 2 pieces, one attached to the cab, the other a removable lenses cover.
/ 474 cab dome light bulb replacement #2
I'm firmly in the "If it 'aint broke, don't fix it" camp.
I've never messed with mine, in fact it is switched off completely (there's a switch position on the light so it doesn't come on when you open the doors).
Just curious what you need the extra brightness for?
/ 474 cab dome light bulb replacement #3
On my cab Kubota, the lens (outer cover) pops off and my conventional bulb expired so I installed an LED. Mine is a long one that fits in the clips in the base.
Used a small flat blade screw driver to remove mine and it didn't break either, came right off. I believe the bulb is called a 'Festoon' bulb.
PORTA POTTY (A67714)
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
Sandblast Skid (A68134)
Sandblast Skid...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A67714)
PALLET OF 2CYL GAS...
