4720 thoughts for the newbie
/ 4720 thoughts for the newbie #1
4720 OWNER
WEBSTER, MN
JD 4720
Have new 4720 with loader, cab, and blade. Sure beats an open station. Has a great heater for moving all the snow up here in a short sleeve shirt, hope the a/c is just as good when it is hot and humid (maybe i can wear sweats and thermal then).
Why put the front axle fill under the engine where have a hard time filling while snaking around the loader arms and such? Doing the 50 hr fluid changes. Engine oil was black as coal, normal for diesels?
Mid mount ports hydraulic hoses for the loader get hit by the front tires when turning sharply to the right.
Is it the weight or the HST that means that Deere does not recommend this tractor for a baler and haybine? Seems like it has more than enough power.
Do they really mean FEL greasing every 10 hr? Between snow and moving bales constantly using the FEL.
/ 4720 thoughts for the newbie #2
Don't know the answers to all your questions, but I do know:
- Black oil is normal for diesels - it's the soot.
- The more you grease, the longer the bushings will last.
Tim
/ 4720 thoughts for the newbie #3
Black oil is normal for some diesels. I owned an 87 Jeep Cherokee and as soon as it was started after an oil change the oil was as black as coal.
With the cab tractor get the optional mirrors for better visibilty and the horn for getting someones attention when needed. The engine block heater is also a nice option if you have cold weather.
The rear wiper is also a nice feature if you work when its raining or in blowing snow.
I also installed the vertical exhaust to get the exhaust out of my face when hand loading material or tools into the bucket.
Sincerely, Dirt
/ 4720 thoughts for the newbie #4
Your killing me. I have an open station 4720. My wife keeps bugging me to get a 4720 cab. She doesn't like the 5525 - too big.
Mine is on the right side of the axles housing on the top. There is it on yours?
Black oil - good that you changed it. It does not take long for it to get nasty - change often.
What type/size of tires? I have R4s - no problem. Might be different on the cab.
What baler? I thought it was OK for the sqaure balers.
Weight really is the issue. In many ways, I could have bought a 4320 or 4520 for what I do. it think it is number games these days. I wanted to pull a 15' batwing with my 4720. it meets the min power requirement. I am not sure I like the electronic PTO engagement - it has got to be hard on the tractor trying to get all that stuff moving.
Also, the batwing weighs more than the tractor...could be ugly.
Yeah - it seems a tad overkill. Mine does seem to use it. The intent is not skimp on grease - it is cheap.
D.
Just figured it would be a whole lot easier to do the front axle fluid change if the fill port was off more to one side so could just fill with a regular funnel instead of a flexi one.
Have the R4 ag tires and mid point hydraulics to the loader, the cleats just touch when trying to turn really sharp right. Wonder if a bungi would wear too much on the hoses??
Have the inside mirror for back viewing, try to keep the outside stuff to a minimun so do not wrap it around a tree or something.
Except for those 2 days a year when it is nice then the cab is definitely a winner, keeps the noise down as well and some feel it will reduce the incidence of skin cancer.
Well, time to go grease the loader since will be below zero soon and do not wnat to do it then. Plus the cattle and donkeys are calling for their feeding. The real test of the FEL will be the first of the month when have a cow to butcher out and get it on a trailer to take to the locker plant.
/ 4720 thoughts for the newbie #6
Well, one thing for sure...you'll never have a JD BH attached to your 4720...:rolleyes:
No cabs allowed...:D
/ 4720 thoughts for the newbie #7
There is a pic of a 4720 cab with a BH on the JD website...
D.
/ 4720 thoughts for the newbie #9
There is a pic of the cabbed 4720 with a backhoe on the jd website and JD is comming out with a 448 that works with cabs!
Pricing and info is not yet set, but it is supposed to be out in March. Start saving your pennies.
Massey Ferguson appears to be doing the same thing on their 1500 series tractors. Check out the Massey add right at the top of the page! Backoe and loader appear magically, on the back of the cabbed tractor. Ain't competition great?
To the original poster, Your front R4's have two position settings, wide and narrow. If you are currently running narrow, you may get more clearance for your hoses if you have the dealer move them out to the wide position. Supposedly, the rears have 8 positions.
/ 4720 thoughts for the newbie #10
I wonder if they will have a BH for the 5525 cab.
D.
/ 4720 thoughts for the newbie #11
You would think, with the increased popularity of cabbed tractors, that they would develop a 25 cab series of compatible backhoes.
The nice thing about the 3020 and 4020 series is that they are still fairly easily transportable with an FEL plus BH from an overall size and weight perspective. IE 10,000lb capacity dual axle trailer plus a 10000lb tow vehicle. The half ton 2008 Toyota Tundra could do it with the new 5.7 liter engine and you would still have a pleasant riding vehicle.
A cabbed 5525 with an FEL and BH is gonna have some considerable added weight and just plain bulk-(width,length,height issues) when towing. One big papa. I would think a 3/4-1 ton/dually with a big diesel would be required for this plus a big exponential price increase for the whole rig.
Did have them move the rears so the air is on the inside and they still stay just in line with the bucket. Maybe they did not move the fronts, never thought to check (duh). Needed to use the tractor at the time. Will check tonite after work, during feeding, have a real hard time with that tipping feeling and this tractor is refueling some of my confidence in side hilling. Thanks for the info!
Must be a lot of work for backhoes out there.
D.
Agreed. I think it has more to do with checking the nuts on the loader (tractor only), when was greasing couple of the bearings were loose. 200 foot #'s? I may not weigh that much and cannot get the inpact wrench in there.
/ 4720 thoughts for the newbie #14
Hitachi and others make cordless 18 volt impact wrenches that are very compact, but yet have ton of power. Might help you get to the tough ones.
/ 4720 thoughts for the newbie #15
Agreed - I would probably get it for my open station 4720, I just can't quite justify it yet.
I have a 1 ton SRW that hauls my 24' trailer and 5525 fine. I would not want to go much larger on the load.
D.
/ 4720 thoughts for the newbie #16
That 5525 with cab and mfwd weighs about 7400lbs. Add an FEL and a BH and you're suddenly at 10,000 lbs plus. Add 2500lbs for the trailer and you're towing nearly 13,000 lbs with a 5700lb vehicle. Better have good brakes and flat ground; )
A 4720 with cab, FEL and BH would come in at around 6700lbs total. Big benefit for trailering.
/ 4720 thoughts for the newbie #17
4720 owner,
Did you get a chance to check the front tire positioning yet?
Wide or narrow?
Also, how wide can you go on the rear R4's?
Beef
beefeater said:
4720 owner,
Wide or narrow?
Beef
Nope, had to put hay in and grease the loader and then was too late. I did figure out that the hydraulic hoses fit nicely BEHIND the side of the hood and they are covered so wear should not be a problem.
I think i read in the book that the rears can go pretty wide. Position 1 to 6 if memory serves me. just turning them around gave me about 6" wider and just barely wider than the FEL so good for plowing and moving hay.
Went to Sears and got the longest 15/16th's wrench they had. Nuts were a little loose and tightened up about 1/8th of a turn. Only had to go under the tractor for 2 or 3 of them. With the eccentric bearings i would imagine they are designed to keep the 'slop' out longer.
/ 4720 thoughts for the newbie #19
My 4320 with R4's are set at widest setting (valves inside). The outside-to-outside tire measurement is approx 76". The 4720 with R4's is probably the same.
/ 4720 thoughts for the newbie #20
Thanks sunnyside and 4720,
How much tire is sticking out relative to your rear fenders?
4720, I assume you have the 72 inch bucket? So your outside width is roughly 73?
Addendum,
Just reviewed the online manual for the 4720, The R1 and R4's both come with 8 position rears. They can be set from as narrow as 51 inches to as wide as 75 inches! Two feet to play with, Nice. The fronts have two postions-53 inches or 57 inches.
Beef
