Red Horse
Veteran Member
- Joined
- Dec 12, 2010
- Messages
- 1,198
- Location
- Bolton, MA
- Tractor
- Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
My 4720 has loaded R-4's and about a 550 lb concrete weight block I use a 7' Fisher power angle plow (junk yard cast off that is starting to crack where the two swing cylinders attach to the blade. I could roll a 1/8" steel plate and weld it onto the front, then again it has a poly cutting edge that is well worn (I already trimmed about 1/2" off it with a junk skill saw blade) and I can't find a stock cutting edge with the proper bolt pattern.
So I'm thinking, I will make it through this season but I will head to my favorite salvage yard ithe spring and pick up a replacement. Anyone using an 8' on their 4720? I think the tractor has the power but what tends to happen (I think) with larger blades,when you are angling, instead of pushing, path of least resistance is to slide the entire machine opposite to the side you are directing your snow.
Anuy thoughts?
Anuy thoughts?
