4720 hissing sound when pto under load
   / 4720 hissing sound when pto under load #1
jcalla
Triangle, VA
john deere 4720 pto hissing sound. any ideas?
   / 4720 hissing sound when pto under load #2
Anything getting hot when that happens?
   / 4720 hissing sound when pto under load #3
It appears from viewing 4720 parts catalog that your tractor has a hyd engaged pto clutch/brake. I suggest to determine if your 4720 has a pto hyd test port so one can check pto clutch operating pressure.
   / 4720 hissing sound when pto under load #4
Make sure hyd Rear rear remote levers aren’t stuck & report back.
I had this happen with 4700 & 4720 I use to own.
I have checked rear remote scr's & none are stuck. This just seemed to happen after I got into some real heavy grass and did not ease up right away. I have used it since and it runs ok until I get a load on it. Then it hisses like fluid is bypassing a port and also the engine pours out black smoke like its really under load. Maybe the PTO brake is engaging when it should not. It sure would be nice to find some hyd ports where I could check pressures.
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2021 Ford F-450 4x4 Crew Cab Liftmoore 3612 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
2013 CIMC REEFER TRAILER (A58018)
2013 CIMC REEFER...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A58018)
2005 PETERBILT 379...
