4720 hissing sound when pto under load
   / 4720 hissing sound when pto under load #1
jcalla
Triangle, VA
john deere 4720 pto hissing sound. any ideas?
   / 4720 hissing sound when pto under load #2
Anything getting hot when that happens?
   / 4720 hissing sound when pto under load #3
It appears from viewing 4720 parts catalog that your tractor has a hyd engaged pto clutch/brake. I suggest to determine if your 4720 has a pto hyd test port so one can check pto clutch operating pressure.
   / 4720 hissing sound when pto under load #4
Make sure hyd Rear rear remote levers aren’t stuck & report back.
I had this happen with 4700 & 4720 I use to own.
I have checked rear remote scr's & none are stuck. This just seemed to happen after I got into some real heavy grass and did not ease up right away. I have used it since and it runs ok until I get a load on it. Then it hisses like fluid is bypassing a port and also the engine pours out black smoke like its really under load. Maybe the PTO brake is engaging when it should not. It sure would be nice to find some hyd ports where I could check pressures.
New/Unused Stand on Track Loader (A57453)
New/Unused Stand...
7ft Metal Gulf Gas Pump (A57454)
7ft Metal Gulf Gas...
EZ loader trailer (A56857)
EZ loader trailer...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
Craftsman Utility Work Bench (A55272)
Craftsman Utility...
Ryobi 10 Inch Table Saw (A57454)
Ryobi 10 Inch...
