4720 Grapple
/ 4720 Grapple #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am interestedi n a grapple for my 4720 with 400X. What are people running out there? Does anybody have any pictures, advice, etc?
Thanks,
D.
/ 4720 Grapple #2
I have a 72 inch Anbo grapple rake on my 4320 with 400x loader. I couldn't be happier. The grapple is a beast at 770 lbs. so you want to make sure you have sufficient ballast. I haul logs, branches, brush, etc around with it. It also comes in John Deere green! I think the 72 inch models are going for around $3,400.
Here's a link to their literature if you want to see pictures
anbomanufacturing.com
/ 4720 Grapple
Cool deal and it is the right color. Of course the long unit in black looks really mean too.
How did you setup your valves for it? You need a third valve, right?
Is there anything you would do different?
I need a grapple!
How much ballast are you using?
What kind of ballast?
Thanks,
D.
P.S. - 4720 should be here within the next 3 hours. I woke up early so I did not miss them!
/ 4720 Grapple #4
Yes, you do need the third valve to operate the upper jaw of the grapple. THe control (on my machine) is located right in front of the control for the 3 point. I've seen integrated joysticks where you can control the 3rd valve from the joystick, which would be nice. But to be honest, I don't think it slows me down that much - the controls are only about a foot or so apart. Of course, unless you have two right arms, you can't operate both controls at once. Like anything on your tractor, once you do it enough times, it just becomes natural and you don't have to think about it.
As for ballast, I have my R1 tires filled with Rimguard, which will give you ballpark 800 pounds (give or take a 100). I usually carry my box blade on the 3 point for a little extra. You could leave your MX6 on the back, but for me the rotary cutter gets in the way when trying to back up in tight areas. With my set up, I can go beyond my loader capacity and it won't lift my back end. Just keep your loads low to the ground and don't drive like Dale Jr.
2002 Broce RJ350 Sweeper (A67714)
2002 Broce RJ350...
x (A68191)
x (A68191)
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
UNUSED FUTURE CAT 303 38" EXCAVATOR RAKE (A65055)
UNUSED FUTURE CAT...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
CONVEYOR BELT (A67714)
