4720 attachments ?
/ 4720 attachments ? #1
zieg
Central Illinois
JD6200
Those of you with a 4720 can you tell me what is the widest mower (rotary) that can be used. I have approx 12acres and want to keep mowing time to a minimum. Thanks
/ 4720 attachments ? #2
It is rated for as large as a MX-8 - 8' mower. Conditions will dictate a lot of it. I ran a MX-6 behind my 4720 and unless it is really really thick - you won't have to slow down.
D.
/ 4720 attachments ? #3
I would think that you would have no problem with a MX-10 pull type cutter. With that tractor, the weight of the cutter on the 3PH, not the required HP, will be your limiting factor.
/ 4720 attachments ? #4
Maybe your dealer has one you can demo. 10' is a big mower. The MX-10 is not a flex mower. So, you do have to think about scalping. So, depending on conditions a smaller mower might be better.
D.
/ 4720 attachments ? #5
This is a good time to point out that well prepared fields that are smooth and cleared of all debris can be cut at a faster clip (no pun intended). Likewise if the field is smooth then the chance to make use of the MX10 is viable.
Steve
/ 4720 attachments ? #6
I run a Bush Hog brand 3008, rotary 3pt mower and my 4720 handles it fine. The problem is with anything wider it will scalp uneven ground.
2017 Kenworth T880 T/A Galbreath Roll-Off Truck (A66736)
2017 Kenworth T880...
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
x (A68191)
x (A68191)
84" Smooth Shell Kit (A68134)
84" Smooth Shell...
2014 FORD ESCAPE (A66091)
2014 FORD ESCAPE...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
