4720 attachments ?
/ 4720 attachments ? #1
zieg
Central Illinois
JD6200
Those of you with a 4720 can you tell me what is the widest mower (rotary) that can be used. I have approx 12acres and want to keep mowing time to a minimum. Thanks
/ 4720 attachments ? #2
It is rated for as large as a MX-8 - 8' mower. Conditions will dictate a lot of it. I ran a MX-6 behind my 4720 and unless it is really really thick - you won't have to slow down.
D.
/ 4720 attachments ? #3
I would think that you would have no problem with a MX-10 pull type cutter. With that tractor, the weight of the cutter on the 3PH, not the required HP, will be your limiting factor.
/ 4720 attachments ? #4
Maybe your dealer has one you can demo. 10' is a big mower. The MX-10 is not a flex mower. So, you do have to think about scalping. So, depending on conditions a smaller mower might be better.
D.
/ 4720 attachments ? #5
This is a good time to point out that well prepared fields that are smooth and cleared of all debris can be cut at a faster clip (no pun intended). Likewise if the field is smooth then the chance to make use of the MX10 is viable.
Steve
/ 4720 attachments ? #6
I run a Bush Hog brand 3008, rotary 3pt mower and my 4720 handles it fine. The problem is with anything wider it will scalp uneven ground.
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
CAT D9G Springs (2) (A68134)
CAT D9G Springs...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A67714)
2011 FREIGHTLINER...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
