4710 Relief Valve Noise
   / 4710 Relief Valve Noise #11
First sorry these are so long, but I can't edit them........
for the leakdown...
Solution Number: 44820
Doc ID: LV44820
Solution Summary: 47 & 48 Backhoe used on 4200 4300 4400 4500 4600 CUT cylinder leak down
Publication Date: Sep 7 1999
Complaint or Symptom:
Boom, dipperstick and stabilizer cylinders leak down during operation or transport.
Problem or Situation:
Since the tractors have an open center hydraulic system, some leakage is normal.
Solution:
Use the following information to determine if the leakage is normal or excessive. The dimensions given are the maximum amount of travel of the cylinder rod per minute;
Maximum lift cylinder drop rate from transport
Model 47 - .57 inch/minute
Model 48 - .36 inch/minute
Maximum stabilizer drop rate from transport
Model 47 - .34 inch/minute
Model 48 - .23 inch/minute
Maximum stabilizer retract rate from working position
Model 47 - .23 inch/minute
Model 48 - .15 inch/minute
47, 48
   / 4710 Relief Valve Noise #12
For the rods bending.........
Solution Number: 44822
Doc ID: LV44822
Solution Summary: 47 & 48 Backhoe used on 4200 4300 4400 4500 4600 CUT Cylinder Rod Bends
Dipperstick or Bucket cylinder rod is bent
The operator hooked the bucket around a solid object and used the tractor to pull the object.
The circuit relief the dipperstick was installed in the bottom of the valve instead of the top.
Solution:
Explain to the operator that the backhoe is not designed for this operation.
Relocate the circuit relief to the top (Handle) end of the valve section.
47, 48
Thanks for the input.
I believe that the hydraulic leakdown that I'm experiencing is within JD's parameters (though I don't necessarily consider it acceptable).
I need to look at the valve body to determine if I can swap the relief. Ideally, I'd like to add the same relief valve from the boom spool to the stick spool for an added measure of security. I don't want to revert to the JD control pattern if at all possible. I have a very hard time switching patterns, though I've spoken to several operators who can readily switch patterns with little or no difficulty. I guess I'm just not that ambidextrous.
I'm a little frustrated that JD doesn't recognize that customers' may have a desire to change the control pattern, and doesn't make it a little easier.
Thanks again for the postings.
-Clark J.
Say, that relief noise that was mentioned in the first post starting this thread is a problem known to Deere. Have your dealer check for a DTAC solution or call product support and ask about it. From what I have heard, a new relief valve for the hydro is available that kills that noise. Let us know how it turns out.
DIRT DOG CLR60 60" RAKE (A57192)
DIRT DOG CLR60 60"...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
