Oil & Fuel 4710 fuel gauge readings
   / 4710 fuel gauge readings #1
green4710
Colorado
Timb mentioned in a post he stared his fuel gauge never reads full on his 4710. Mine doesnt either. When totally full, it shows 3/4 at best. Anyone else having this problem? Is this a warranty issue? I know its not a big deal, but for the money these things cost, you'd expect a fuel gauge to read full when full, empty when empty.
   / 4710 fuel gauge readings #2
Actually I wasn't very clear on my message. I haven't had my 4710 long enough or run it low enough to get a good feel over the whole gauge range, but in the top 1/4 it seemed roughly accurate. When the dealer delivered the tractor, the gauge read just a needle's width below full. (I didn't check the actual tank level). I ran it down to just under a 3/4 reading - and then topped it up the tank as high as I thought prudent (but left a small gap below the filler neck). That took about 3 gallons and change. With that I got a reading about 7/8 or a little higher - but still below where it was when I started. So there must be room for a little more fuel.
Hmm. If you're getting at best a 3/4 reading - that is a bit different and sounds like somethings awry.
   / 4710 fuel gauge readings #4
I have a 4300. It never showed over 3/4. The dealer adjusted it. Bent the metal wire holding the flote. It now read full most of the time and will run dry at about 1/3 . It is not a precision gage. I gave up, since I know how it reads it doesnt run dry. Not the best answer but I can live with it.
dpr
   / 4710 fuel gauge readings #5
As I mentioned in the other related post, my 4610 came from the dealer with a screwed up fuel gauge. Never would read over 1/2. It was replaced under warranty and now works kinda like yours. Never reads full when topped off and still has 4 gallons when it's on empty. I have learned to use the time/rpm method to determine when to refuel.
   / 4710 fuel gauge readings #6
The fuel gauge on my 4710 reads full when it is full but when it reads 1/4 it is almost empty. I would rather have it read empty when it is empty. I know when the tank is full. It looks to me like the float is for a tank that is not as tall as the one in the tractor. The float does not have enough range to read correctly at full & empty.
Chris
   / 4710 fuel gauge readings #7
At least we have auto bleed fuel systems!! Imagine NOT having tat on a machine with side skirts, a loader and assorted plumbing in the way... I had to bleed my old Yanmar a few times and it really puts fear in you. It isn't really all that bad, but a real hassle, especially if it's a mile walk to the tools...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
LANESHARK LS2 LOT NUMBER 159 (A53084)
LANESHARK LS2 LOT...
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
