4690 boom 'drop rate'
/ 4690 boom 'drop rate' #1
PeteF
Cincinnati, Ohio
B2710/Loader/4690 Hoe
4690 boom \'drop rate\'
Question for 4690 owners:
My boom lowering or 'drop' rate is very fast and makes operation quite sensitive. The other rates (boom raise, swing, dipper, curl) seem reasonable. The boom lower rate is easily 10 times as fast as the raise rate. Is this typical?
Your input appreciated.
Pete in Cincinnati
B2710/LA401/4690
/ 4690 boom 'drop rate' #2
Re: 4690 boom \'drop rate\'
My 4690 behaves the same way. Boom up/down (and swing to a lesser extent) are MUCH faster that dip and curl. It really has a hair trigger on the left joystick. It has taken some getting used to. I'm not sure if it's supposed to be that way or not. According to the instructions there are restricting orifices in the valve body to control speed. I was going to check that they were installed right one of these days but I've never got around to it.
Dave
/ 4690 boom 'drop rate' #3
Mine has been that way since I got it. I too just got use to it, but I've since got tired of easing it down so I am going to install an adjustable flow control valve on the boom cylinder. This will allow me to set the drop rate to what I like.
2011 International 4300 Versalift Bucket Truck (A64194)
2011 International...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
