4630GSTC Speedometer Calibration
/ 4630GSTC Speedometer Calibration #1
DUMBDOG
Central ND, Central FL
NH 1630 W-7308 FEL/ Kubota L4630GSTC W-LA853 FEL WQ/A-CC 2544
We are back up north and starting to till the garden.
Before we left had a 4630GSTC delivered and puttered around for a while before we left, noticed a tag on the hand throttle about the speedometer.
Tonight I checked it and when the delivered the tractor they had not calibrated the speedometer. Just took a couple of minutes, but I would think that this is something the the dealership should have done.
Has this happened to anyone else?
/ 4630GSTC Speedometer Calibration #2
I have not had that experience but it is so easy to do especially for folks with multiple tire sizes. I know the dealer does it when they get it since it is in the assembly instructions. What tires did you get? I believe it comes set for R1's.
The tires that came with the tractor were R1's, but it was not set for them, the setting was for something that was not in the manual.
/ 4630GSTC Speedometer Calibration #4
Dumbdog, could you post the setting procedure? The dealer forgot to give me the tag that tells you how to do it.
/ 4630GSTC Speedometer Calibration #5
I can FAX you the whole thing. It is in the assembly instructions. My dealer gave it to me. It involves holding down the two buttons before turning on the key and entering the appropriate code for the tractor model and tire type. Rat...
/ 4630GSTC Speedometer Calibration #6
Rat I've got a fax # at work but it would be quite long distance on your bill, I'm about 6000 km from you as the crow flies...
Any way to scan and email it? If not I'll message you my fax #.
The instructions are down at the farm right now, if Rat does not get them to you, I can post them here tonight. It is quite simple to do.
/ 4630GSTC Speedometer Calibration #8
Didn't happen to pick up the instructions?
Ken
Keep forgetting to pick them up, note in my pocket will get it done tonight and post. Sorry for the delay. /forums/images/graemlins/blush.gif
/ 4630GSTC Speedometer Calibration #10
/forums/images/graemlins/smile.gif No worries, I just wanna know how fast I'm going down the road!
/ 4630GSTC Speedometer Calibration #11
See attachments
Page 1
Just go it from tilling and brought the book in this time, but Rat beat me to it. It is quite simple just follow the directions and you will know how fast you are going. After doing mine I knew when I was tilling at 2.4 MPH, before setting mine when I thought I was doing 2.0, the actual speed was about 3.6 so who knows what the factory was set for, not for R-1's for sure.
/ 4630GSTC Speedometer Calibration #15
Thanks for the info! I wonder what A, C, and D modes do? Is there a lot of other info in the setup manual? I see the page numbers are pretty high...
Maybe I should try to get a copy of the manual at the dealer...
Ken
/ 4630GSTC Speedometer Calibration #16
It does not mention what those do in the manual. It mostly shows all the unassembled parts, how they go together. For instance, the front axle does not have the hubs in them. It shows how those go together. It also mentions how long it should take the dealer to assemble the various tractors. It's about 1.5 hours.
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
