4610 ignition switch access
   / 4610 ignition switch access #1
Kenkjsm
Perryville, MO
Ford 4610 Utility, John Deeere 3020 Gas
My 4610 Utility, no cab, starts fine if I jump the terminals at the starter, so I want to chase down the wiring.
What is the simplest way to get to the ignitions switch?
Do I have to remove the hood?
   / 4610 ignition switch access #2
Remove the key and retainer nut on the outside of the switch. You have almost enough wire in the harness to drop the switch down below the cowl it is mounted in. Be safe, remove the negative battery cable first.
Thanks. I just hope it's not a mouse problem!
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53472)
2022 NEW HOLLAND...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
JOHN DEERE S780 LOT IDENTIFIER 36 (A53084)
JOHN DEERE S780...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
