4600 ford tractor
   / 4600 ford tractor #1
sirfixalot
Blountville, tn
ford 4600
I have a 4600 ford diesel tractor gaining oil. It's not colored,muddy, smells like diesel. I've been told that i have a fuel injector leaking. is there anything else could cause that to happen.
   / 4600 ford tractor #2
Could be the fuel lift pump. If the diaphram has a hole in it fuel can leak past the pump directly into the base.
   / 4600 ford tractor #3
No lift pump on a 4600. Could be a fuel injector, injector pump shaft seals, or less likely a failed thermostart unit. Could also be a failed power steering pump, but that would not smell like diesel.
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
