3-Point Hitch 4530 3-point hitch hydraulic question
/ 4530 3-point hitch hydraulic question #1
DenisM
Bronze Member
Harford County, Maryland
Looking for one now.
Still getting used to my 4530. The 3-point lift works fine in the lifting or up direction but does not have any force in the down direction. I have to stand on the arms to get them to fall. Is this normal?? If it is, how can a post hole digger work? I need to sink some posts and am looking for a digger now.
/ 4530 3-point hitch hydraulic question #2
they should come down without having to stand on them. make sure the hydraulic valve is all the way open (the little knob under the seat, between your legs if you are sitting in the seat)
The valve you mentioned is open. What else might cause this problem? Is hydraulic power applied on the down stroke?
/ 4530 3-point hitch hydraulic question #4
Denis,
The phenomenon you describe is fairly normal I think... especially when the tractor is cold. The TPH just needs some weight on it to get it to fall. Once the tractor is warmed up, it should fall just fine.
My 3525 is the same way... actually, most tractors that I've been around have done this at one time or another.
There is no downforce on the 3 Pt. Hitch. It falls by gravity alone... when the hyd oil is cold and thicker, it just takes a few more lbs than what the hitch weighs to get it to go down.
It is starting to get cold around here; the thick oil makes sense.
The valve that was mentioned above, according to what I've read in the owner's manual, is used when moving the tractor to make sure the hitch does not fall; an on-off valve to lock the hitch in the raised position. Can this valve also be used as a variable valve to control the rate of rise and lowering of the hitch?
/ 4530 3-point hitch hydraulic question #6
DenisM,
That valve would only control the rate of lowering on your 3PH. There is a little bracket that keeps you from closing that valve all of the way. Remove the bracket and close the valve all of the way, then quickly raise and lower your position control lever a few times. The system will squeal when in the up position, and this is hyd fluid bypassing the system relief valve. This may release some trash in the valve that could be causing your problem. Open the hand valve back up and put back the bracket and try the 3PH. This may or may not help your problem, but it is the first thing I would try. Good luck with it and let us know what transpires.
Tried what Galen suggested with the valve; but hitch still would not lower by itself.
Decided to warm up tractor by riding it down the road. It got up in the 60's today. Anyway, after the oil was good and warm, the hitch lowers by itself; slowly but it goes down by itself. Guess Brian was right.
The tractor needs to be broken in a bit. Will probably change to synthetic oil at first change and this will help also.
Thanks for the info and help.
Denis
/ 4530 3-point hitch hydraulic question #8
Denis
Hey Denis, just letting you know my new 4530 does the same thing. Stays up or sometimes is slow to lower until warmed up. I have used my post hole digger on it. It works fine with an implement attached.
Mud
/ 4530 3-point hitch hydraulic question #9
I'm assuming that you don't have anything attached to the 3pt. hitch... and I have seen several tractors that don't lower well without any weight on them. If you were to put a post hole digger on it... it would lower easily assuming there isn't an actual problem with the tractor.
Yes on the fact that there is nothing attached to the hitch when I asked the question above.
/ 4530 3-point hitch hydraulic question #11
My hitch on my 4110 never has gone down without something on it no matter what the temp. It has almost 6 years and 1450 hrs. and still the same as new. It only takes ever so slight weight to lower it - one hand or a foot will do it warm or cold.
2010 GMC SIERRA 1500 (A67714)
2010 GMC SIERRA...
2012 Bush Hog Flail (A64911)
2012 Bush Hog...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
Chariot Scrub 20 Electric Floor Scrubber (A64194)
Chariot Scrub 20...
Vintage Grease Gun (A64912)
Vintage Grease Gun...
2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
