4510 Mahindra Lost Glow Plugs
   / 4510 Mahindra Lost Glow Plugs #11
Hopefully 8 pages of info will be posted. Also have part numbers and photos if needed. Trust this may be of some value. Sorry about the delay in getting this to you. Holidays.
  • Mahindra 4510 wiring diagram p. 1.pdf
  • Mahindra 4510 wiring diagram p. 2.pdf
  • Mahindra p. 3.pdf
  • Mahindra p. 4.pdf
  • Mahindra p. 5.pdf
  • Mahindra p. 6.pdf
  • Mahindra p. 7.pdf
  • Mahindra p. 8.pdf
Nonsense! Thank you very much, I will dig in this week.
   / 4510 Mahindra Lost Glow Plugs #13
keep us posted with your results
   / 4510 Mahindra Lost Glow Plugs #14
My Ford had a coil of heat wire that served as a glowplug indicator that burned in half.
I reconnected the half that remained, and it has worked fine ever since.
I don't know if your tractor has a similar indicator wired in series with the glowplugs, but it is worth looking at.
   / 4510 Mahindra Lost Glow Plugs #15
Hope you got the glow plug issue resolved.
Sorry for the late response, been using starting fluid so far. No luck with the glow plugs. I found a bad connection on the line in coming from the battery, but that wasn't my issue. I am starting to lean towards having an issue with the ignition switch. The light that used to come on the dash to indicate 'Glow', no longer lights. It is quite cold right now, but it is something that I have to get into sooner rather than later.
2017 Liebherr L566 X Power Articulating Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel (A59076)
2017 Liebherr L566...
TANK MANIFOLD (A58214)
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
