4510 Mahindra Lost Glow Plugs
   / 4510 Mahindra Lost Glow Plugs #11
Hopefully 8 pages of info will be posted. Also have part numbers and photos if needed. Trust this may be of some value. Sorry about the delay in getting this to you. Holidays.
  • Mahindra 4510 wiring diagram p. 1.pdf
  • Mahindra 4510 wiring diagram p. 2.pdf
  • Mahindra p. 3.pdf
  • Mahindra p. 4.pdf
  • Mahindra p. 5.pdf
  • Mahindra p. 6.pdf
  • Mahindra p. 7.pdf
  • Mahindra p. 8.pdf
Nonsense! Thank you very much, I will dig in this week.
   / 4510 Mahindra Lost Glow Plugs #13
keep us posted with your results
   / 4510 Mahindra Lost Glow Plugs #14
My Ford had a coil of heat wire that served as a glowplug indicator that burned in half.
I reconnected the half that remained, and it has worked fine ever since.
I don't know if your tractor has a similar indicator wired in series with the glowplugs, but it is worth looking at.
   / 4510 Mahindra Lost Glow Plugs #15
Hope you got the glow plug issue resolved.
Sorry for the late response, been using starting fluid so far. No luck with the glow plugs. I found a bad connection on the line in coming from the battery, but that wasn't my issue. I am starting to lean towards having an issue with the ignition switch. The light that used to come on the dash to indicate 'Glow', no longer lights. It is quite cold right now, but it is something that I have to get into sooner rather than later.
2013 GMC Silverado 3500HD Flat bed (A55973)
2013 GMC Silverado...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
LOT: (10) Chairs (A59076)
LOT: (10) Chairs...
