4510 front steering knuckle leaking
/ 4510 front steering knuckle leaking #1
BrianHat
John Deere 4510
Bought this tractor from my FIL and the front steering knuckle was leaking before I bought it. He had it fixed by a reputable guy and now it’s leaking again with hardly any use from the fix. It seams this is a common problem on these tractors. My question is it leaking because of a different problem ( like bearing issue or pinion shaft distance, like a shoulder is wore). I think someone had a thread on a different model tractor I thought, but any help would be greatly appreciated. Thanks again
/ 4510 front steering knuckle leaking #2
What brand is it?
John Deere 4510
/ 4510 front steering knuckle leaking #4
I have a NH TC45 that’s leaking a bit on one side. The manual says 80/90 GL5, but I wonder if corn head grease (00 flowable grease) would work.
This thing is it’s leaking a lot and I only used it like one time since it was fixed. It seems like it (bangs) into four wheel drive (front wheel assist). Not sure if this has something to do with it or if that is another problem?
159120 (A60430)
159120 (A60430)
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
Rhino HPHD (A64127)
Rhino HPHD (A64127)
John Deere 4040 Tractor (A64047)
John Deere 4040...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
