4510 front steering knuckle leaking
/ 4510 front steering knuckle leaking #1
BrianHat
John Deere 4510
Bought this tractor from my FIL and the front steering knuckle was leaking before I bought it. He had it fixed by a reputable guy and now it’s leaking again with hardly any use from the fix. It seams this is a common problem on these tractors. My question is it leaking because of a different problem ( like bearing issue or pinion shaft distance, like a shoulder is wore). I think someone had a thread on a different model tractor I thought, but any help would be greatly appreciated. Thanks again
/ 4510 front steering knuckle leaking #2
What brand is it?
John Deere 4510
/ 4510 front steering knuckle leaking #4
I have a NH TC45 that’s leaking a bit on one side. The manual says 80/90 GL5, but I wonder if corn head grease (00 flowable grease) would work.
This thing is it’s leaking a lot and I only used it like one time since it was fixed. It seems like it (bangs) into four wheel drive (front wheel assist). Not sure if this has something to do with it or if that is another problem?
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
UNUSED TAYLOR-WAY 6' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
2013 John Deere 329E High Flow Compact Track Loader Skid Steer (A61567)
2013 John Deere...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
