4500 Tach problem
/ 4500 Tach problem #1
Mahindracub
Hello Everyone,
I just bought a Mahindra 4500 4 wheel drive. It has approx 80 hours on it. I was using a 1963 massy 35; this is a powerful tractor!
Only issue I have is the tach not working. It will jump up when I increase the rpm's but just jumps all the way over until it is pegged out. Has anyone else had any issues like this?
Kerry
/ 4500 Tach problem #2
Hello Everyone,
Kerry
I've got a 6000 with over 400 hours on it and I haven't seen an issue like yours. I believe the tack is electrically operated....so check the connections first. What year is your 4500? BobG in VA
/ 4500 Tach problem
2002 model. The hour meter works, tach does not.
Where are you in VA, I am in Mt airy nc
/ 4500 Tach problem #4
We're up here in Prince William County (next to Manassas Battlefield Park). My 6000 is a '02 as well. I'd get in touch with a Mahindra dealer about the tach, especially if the hour meter works...BobG in VA
/ 4500 Tach problem
Ok thanks for the reply. I have a friend up in the NOVA area.
Kerry
/ 4500 Tach problem
I took the alternator to a local electric motor shop, they installed a new rectifier, cost $38.00 tach now working and alternator charging.
Kerry
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2022 EZ-GO ELITE...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
7002SFL (A61572)
7002SFL (A61572)
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
