4500 muffler
/ 4500 muffler #1
tractornewby
Rio Frio, Texas
'02 Mahindra 4500
Has anyone in here moved their muffler on the 00 series so that it doesn't stick straight up? With low tree limbs, I'd prefer to not have to drive so cautiously to avoid low limbs. I want to lower the muffler or make it horizontal instead of vertical. Has anyone done this?
I also want to ad that I installed the Pat's Easy Change 3-pt hookups and they work great. It used to take me anywhere from 20-30 minutes to connect my Howse 6' shredder and I pulled a muscle in my back last week while connecting it using a rock bar and 8# sledge hammer. I just installed the Pat's Easy Change system this evening and with a single attempt, I had my shredder loaded on the 2 lower arms within seconds of starting my tractor.
Regards,
TRACTORNEWBY
/ 4500 muffler
Regards,
TRACTORNEWBY
/ 4500 muffler #3
Westendorf Loaders
A TA-LOADER TO FIT YOUR EVERY NEED
POWER QUICK MOUNT
Unlike others, you can stay in the seat. Automatically locks on
no pins to align -- no bolts or wrenches -- no dangerous stands.
SNAP-ATTACH
Automatically hooks up attchment (Pat)
TA-160 LOADER
POWER QUICK MOUNT
Allows you to hydraulically remove your loader in minutes; with no tools or dangerous stands, leaving your tractor free for other uses.
Joystick Valve & Manifold Package
Include in Price
Nobody Beats Westendorf!!!
Quick On & Quick Off - Detach Entire Loader In 60 Seconds!!
Loader Comes Off Clean Not Cluttered.
Westendorf's Quick Attach System
Westendorf Quick Attach Canopy Can Be Removed Quickly & Easily!
The Hydra-Snap Works Quickly & Easily!!
Mahindra 6000 w/Westendorf TA-25 - Lift capacity 3000lbs - Lift height 9'5" - Shown with a QA bucket and single lever joystick valve.
The Westendorf TA-25 quickly and easily slips off the tractor & Westendorf does not need a stand rather the sub frame drops down to create the loaders self supporting stand. The loader can be taken off the tractor in less than 60 seconds.
The Westendorf TA25 bucket QA system quickly and easily allows the operator to change from buckets to other front accessories without having to drive out bucket pins.
When mounting the Westendorf TA25 loader the muffler is relocated downward to be well protected by the loader rear axle support thus making the tractor a handy tool to use in poultry house situations.
Misc Pictures
For More Information Call
Carraway Hay & Tractor
1-903-485-2061
/ 4500 muffler #4
Westendorf Loaders
POWER QUICK MOUNT
SNAP-ATTACH
TA-160 LOADER
POWER QUICK MOUNT
Include in Price
Misc Pictures
1-903-485-2061
/ 4500 muffler
thanks for the reply whisperer, but the "quick attach" I installed was for the 3-point hitch, not the loader. I have never had a need to remove my loader or my bucket. The process of attaching my shredder on the 3-point was very difficult. I used a 6' rockbar to move the shredder bit by bit to get it aligned with the lift bars and then I had to use a sledge hammer to move the lift bars into place. This is something I didn't look forward to. It was equally hard to remove the shredder from the 3-pt. Now, with Pat's Easy Change System, it's no problem at all.
I haven't looked real closely at the muffler setup to see if I can rotate it down or not, but I do want to lay it horizontally, even if I have to get a custom pipe made to allow for this.
What kind of fish do you whisper to? Nishikigoi?
Regards,
Tractornewby
/ 4500 muffler
Regards,
Tractornewby
/ 4500 muffler #9
If you scroll to the bottom of the page that fish_wisperer linked you'll see an example of the exhaust rerouted down in front. I think that may have been why he posted the link... to show an example of the exhaust being rerouted. Perhaps you can contact the folks in the link (Carraway Hay & Tractor) to inquire about rerouting your exhaust.
BR
/ 4500 muffler #10
BR
/ 4500 muffler #11
When you installed the quick hitch-did you use a allen
wrench to make the hitch point straight back. another
words---connected, do the hitches point straight back or
do the angle out?
/ 4500 muffler #12
do the angle out?
/ 4500 muffler #13
there is a picture of a rerouted exhaust in that link, its on a 6000 but a 4500 would be the same.
/ 4500 muffler #14
/ 4500 muffler
Yes, I used the 4 allen-head bolts to adjust the alignment of the end pieces, per the instructions. The lift arms on my 4500 were already angled toward the center at the end of the arms. I had to use the provided shims to adjust the height of the end pieces and I used the 4 allen-head bolts to adjust the left/right alignment. When I aligned the end pices, I had the lift arms in their highest position. When I lowered them to pick up my shredder, I immediately saw that my adjustments should have been made with the arms in the normal/lower position. I had to readjust the end pieces so they would match the angles of the lift pins on the shredder. Here's a photo of my Pat's Easy Change system with the optional spacer bar:
Regards,
Tractornewby
/ 4500 muffler
Regards,
Tractornewby
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
2015 Isuzu NPR HD Porta John Recovery & Cleaning Truck (A62613)
2015 Isuzu NPR HD...
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
