Oil & Fuel 4500 fuel filter
/ 4500 fuel filter #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
when i did my 50 hr service i was going to replace the copper washer on top of the fuel filter but i guess you cant pull that bolt all the way out without removing the starter. am i wrong? i am talking about the primary filter, the most aft one.
tom
/ 4500 fuel filter
surley sombody knows... i dont want to pull that starter if i dont have to. plus it does leak since i changed the filter, i need to replace that washer.
/ 4500 fuel filter #4
There were some posts a few weeks or so back about Mahindra filters that had a faulty seal. The shape of the seal was changed and the newer filters do not leak. This could be the problem you are experiencing. Is the filter itself leaking?
/ 4500 fuel filter
no its on top of the filter, i changed the seal when i changed the filter. the mechanic said to change the washer to because they will leak. this is normal, anytime you have a copper washer it is a crush washer, one time use only. when i try to remove the bolt to replace the washer it hits the starter before it comes out of the filter housing.
/ 4500 fuel filter
maybe i just needed to jerk on it harder, but i would like to hear it from someone else before i make it worse. the leak is small and i could live with it till the next filter change.
/ 4500 fuel filter #7
I also replaced my fuel filters at the 50 hours mark. In thinking about it afterwards, I had to really wonder if it was really necessary. Just how many particulates can there be between a new tank and the fuel lines to the injector pump to completely foul the primary filter?
Mine is the 4500 FWD but essentially the same tractor. Incidentally, the FWD takes a different secondary filter than the 2wd. Instead of dropping the starter, I took the bracket that holds the two fuel filters off the engine and it gave me all the room I needed. Seems like a lot of work but really not that bad. Get your metric wrenches/sockets out and it's not too bad of a job. I hope this helps you out and good luck!
/ 4500 fuel filter
thanks,,, just wanted to make sure i wasnt imagining things.
tom
/ 4500 fuel filter #9
</font><font color="blue" class="small">( I also replaced my fuel filters at the 50 hours mark. In thinking about it afterwards, I had to really wonder if it was really necessary. Just how many particulates can there be between a new tank and the fuel lines to the injector pump to completely foul the primary filter? )</font>
My dealer told me the fuel filter generally doesn't need changed at the 50 hour mark.
/ 4500 fuel filter
well that wasnt so bad,, got rid of the leak. they did give me the wrong secondary filter, but the old one was spotless so i just put it back in.
thanks tom
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
Massage Chair (A65640)
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT4EHFV0598 (A65563)
2014 Freightliner...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
100 gal Portable Fuel Tank (A66408)
100 gal Portable...
16ft. Field Cultivator (A65640)
16ft. Field...
