445 float detent
/ 445 float detent #1
beenthere
Super Star Member
Southern Wisconsin, USA
JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
The JD 445 will not snap into the detent and stay in float. Pops right out when using the front blade.
Any ideas what the problem would be? tks.
/ 445 float detent #2
sounds like you got crud on your balls. :laughing:
there have been some threads on this, spring loaded detent balls sometimes
get gummed up and they don't hold while in float. sometimes you can take off
the cap on the scv and clean it all out good, and re assemble with success..
if i remember right a little tug on the spring to lengthen it might also help.
/ 445 float detent
:laughing: :laughing: :laughing:
Good one, and thanks for the tip too.
Will give that a try, and see if it works. The fluid and filter have been changed, but this float valve only gets used during the winter with the plow so may be a collection point for any small bit of debris.
/ 445 float detent #4
they sell the guts for that kit, but sometimes you can get by
without buying them.
good luck
/ 445 float detent #5
look at the pic, see part 5, balls
/ 445 float detent #6
Yup, dirty or worn out balls...happens to the best of us :)
/ 445 float detent
Thanks, as that looks real simple and straight forward to do. I was thinking I would have to pull out the spool.
Will give it a shot when I get to where that tractor is at.
Tires and Rims (A65640)
Tires and Rims...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
