4430 transmission warning light
/ 4430 transmission warning light #1
blacksmith74
JD 4430, 2550
Transmission warning light on my 4430 does not flash with key on, engine not started. It does come on when cranking starter and goes off when engine starts. Any ideas?
/ 4430 transmission warning light #2
IIRC what you stated is the correct operation of trans oil light. Have you checked in your operators manual?
/ 4430 transmission warning light #3
Which transmission do you have? Quad range, Syncro-Range or Power Shift.
Thank you Hoosier Hay Man -
I have quad transmission. The operator manual says the transmission warning light should flash with the key on, but not starting and engine not running.
/ 4430 transmission warning light #5
I checked mine and I need to see if my light is burned out. It doesn't come on at all. My filter light either. I have done 2 transmission oil changes in the last 4 years and it works fine.
/ 4430 transmission warning light #6
I started mine this morning and pulled it out of the shop. It also flashes while cranking and goes off when started. Mine is a quad range as well. I read the manual and it says flashing with key on and not starting.
I would say flashing with it cranking is normal as I believe it has always done that. I guess I never noticed what the manual said. My guess is while cranking the flow and pressure is low so the light flashes until it starts and pressure comes up. If you keep the filter and oil changed in it every 200hrs it should be fine.
2016 FORD F-150 (A67714)
2016 FORD F-150...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
2013 Lincoln MKX SUV (A66738)
2013 Lincoln MKX...
93b (A65054)
93b (A65054)
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
