4410 Trouble light
/ 4410 Trouble light #1
countrybumpkin
Elite Member
Kioti, kubota
A buddy of mine just bought a 4410 and while bush hogging with it he says after a few minutes, a flashing light with a wrench lights up. The PO said to use a higher RPM but that still doesn't work. The light will reset after turning off the tractor but comes back on when using to PTO. I told him I would check with you guys because I don't have a JD. Thanks
/ 4410 Trouble light #3
That light is telling you that the self diagnosis is detecting a problem. Call your dealer. I have a 4410. When I over work the FEL ie trying to push a root out and picking up the front end and try to back up the light will blink, and I will not move until I "unload" the FEL hydraulics. Then the light goes off and I can resume forward backward motion. If this is why your light is on I hope I have helped if not call your dealer.
/ 4410 Trouble light #4
The blinks are a code consisting of various combinations of 4 long and short blinks that repeat after a pause. Sometimes you have to watch it for a while to pick up on the pattern. It is possible to have more than one error code which can add to the confusion.
If you can read the code and report it back, someone here can tell you what it means. The difference between a short and long blink is the time that the light is on, not the time between blinks. The code should be something like "short-long-short-short."
John Deere 4044M (A60462)
John Deere 4044M...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A61573)
2015 Ford F-450...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
