4410 leak
/ 4410 leak #1
cef2lion
Central PA
JD 4410, JD455
I have a 2003 4410 with 160 hours. Just recently I noticed a small amount of hydro fluid on the center pulley of my MMM. I saw small amounts of fluid on the plate above that covers the cavity where one of the hydro filters is located. I removed plate but couldn't tell where the fluid was coming from. I checked the filter and it wasn't loose. I clean it all up and ran it for a week and noticed fluid again. Not a lot.
I called the dealer and they sent service out. The service tech just called from my house and verified the leak. He cleaned the area and ran it a bit but couldn't detect the leak.
I'm going to monitor for awhile but I'm not sure how to proceed at this point. The dealer has noted the problem even though my warranty is good through next summer.
Craig
/ 4410 leak #2
May need to be brought into the shop and split. Reseal and put back together.
/ 4410 leak
I'm going to talk to the dealer about options and have them contact Deere to get there input. The service tech did say something about the transmission installation and sealing vs gaskets. My tractor has never been split to date. The tech did ask if it might have leaked more with the MMM installed. Not sure if he was thinking the weight of the MMM in that area.
My tractor at one time was taken in for a recall to replace the transmission. It was brought back as it didn't need the recall and was never touched. The recall kit had a replacement transmission and a tube of sealant??
While at the Dealer a few weeks back I walked up to a new 4410 and looked under. I noticed a small amount of hydro fluid on that plate where my unit leaks. The leak is not great and often is just droplets on that plate. Wondering if others might look for this issue to see if it might be a common problem?
Craig
/ 4410 leak #4
I have seen a few of them, some never noticed by customers and taken care of at later dates. I don't think there is a gasket, just sealant. Once it's been done, I haven't seen one come back for that leak again, not yet at least.
You should end up with a full transmission service out of it, they might charge you for the filter if you want that changed also.
/ 4410 leak #5
How about removing the MMM and placing newspaper under the tractor on the garage floor. See if this will help you locate the leak source. I have a 4300 and had a similar problem. Found it to be a valve drain that I had to close with a wrench to stop the very slow drip.
/ 4410 leak
I have the leak isolated to an area but unable to zero in on it. I'm starting to think it might require the unit to be split and resealed.
Craig
/ 4410 leak #7
If the leak is real small maybe you should just let it be. They could cause more problems by fixing it.
/ 4410 leak
The leak is small but I have a MMM. I find the fluid on the center pulley on the MMM. I don't want the fluid getting on the MMM belt. Since I have warranty I think I will keep at the dealer until it gets fixed correctly.
Craig
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2014 Jeep Cherokee Limited SUV (A66738)
2014 Jeep Cherokee...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A67714)
TIRE RACK WITH...
