4400 running backwards
/ 4400 running backwards #1
simonmeridew
Northeastern Vermont
Kubota L4400
It happened twice over the new years weekend: I was winching out a large white pine with my L4400 and Farmi winch, when the log caught in the snow, slowed then briefly stalled the engine, then I quickly released the winch cord and the motor had started again, but this time running backwards. I immediately ran to the key and shut it off. How do I know it was running backwards: the first time I didn't, the second time I did: the tach showed no RPMs and the oil light on the dash was lit.
I figure that I stalled the motor, and there was a potential energy stored up in the winch cable and caught log, which wanted to pull the winch cable back out, and when the motor stopped and the cable pulled back out the motor started running backwards. No idea how much power it had, I shut it off within a couple seconds, but it was idling very smoothly. Sounded normal.
simonmeridew
/ 4400 running backwards #2
Wow, that could cause real damage to your motor. I imagine that both
your engine oil pump and implement pump would cavitate almost
immediately. And, as you saw, no oil to the bearings.
/ 4400 running backwards #3
Im not sure if that is possible?? I would think the injection EMC would not let this happen. Unless the existing fuel pressure is the only thing that was still sending fuel thur the injectors, It may not have ran very long like this. But I find it hard to believe that could happen, though from what you describe that would be very good circumstance that in theroy would cause this to happen.:eek: :eek:
/ 4400 running backwards #4
I have seen this happen before on 2 stroke diesel engine but not on 4 stroke. May be we will learn how this happened. I'm interested.
/ 4400 running backwards #5
I have had it happen to me with both a 2 stroke and a 4 stroke diesel engines in the past.
A 2 stroke Detroit ( several times) but also a Cat 4 stoke.
Can't explain why they can run backwards. I just know I've seen it happen.
/ 4400 running backwards #6
Ya know, I've actually seen this happen more than once. The last time I saw it happen was on an old Mack dump truck with a 237 HP Mack engine. The guy was backing down into a ravine. I'm not sure what he did with the clutch, or what gear he was in, but it sounded awful, and black soot poured from the air cleaner.
/ 4400 running backwards #7
The L4400 does not have an engine computer that controls the injection. It is all mechanical and will run backwards.
/ 4400 running backwards #8
As they say on the Bud-Light commercials, "Dude!"
Are you running the 'bota at PTO speeds or are you running light on rpm's? It shouldn't stall out if running at 540 rpm. Also, adjust your slip clutch if it has one. It may be rusted froze - happens all the time. If it only has a shear bolt, get a slip clutch.
Ever watch NASCAR? when they spin and go backwards the engines are forced backwards and they blow every time. Bearings don't like the no-oil diet. They (racers) can afford it as the engines are cheap disposable deals, but our tractors are expensive! (joke! hold your fire NASCAR fans, I know what they cost.)
To be clear on you issue. When it bogged, did you release the winch and the engine fired right up from an "off" state? Can you reach back and depress the tractor clutch by hand, then release the winch? That may stop the problem. Still, I think a correctly operating slip clutch would be the right solution.
Whoa! Had a brain dealie - you know, a thought. Isn't there supposed to be an overrunning clutch in the PTO to keep just this from occuring? (There is). You may have an issue in the 'bota that needs attention. If that ORC is froze and transmitting torque from the PTO to the engine, it will transfer torque from a rotary cutter also. When that happens the tractor keeps moving forward no matter what you do. Talk to some grey beards that drove tractors with non-live PTO's. A lot of barns, trees and ditches were run into over the years.
/ 4400 running backwards #9
I also suspect your slip clutch isn't doing it's job. No way you should be able to stall your engine like that, unless you're operating at idle speeds. If you are, rev it up some before you destroy that baby by running it backwards. Running backwards is VERY bad. You can't see where you're going! :)
/ 4400 running backwards #10
I'm not certain of this but I think the older tractors that had the PTO and transmission tied together needed an ORC. When the clutch was depressed the PTO was still connected to the Transmission (if it was engaged) and the energy in the implement could move the tractor.
The L4400 has an independent PTO so it is not tied to the transmission. There is probably not an ORC since the PTO is tied directly to the engine. I suspect that the incidents of running backwards is quite unusual and Kubota didn't take this winching scenario into account.
Some skidding winches have slip clutches to prevent stalling. Check to see if yours has one. It may be frozen or need adjusting.
Adding an external ORC would solve the running reverse problem too. It would not prevent stalling though.
/ 4400 running backwards #11
Can't the machine in theory feed itself with oil getting past the rings and into the pistons? I guess that assumes an older, worn machine. I have heard of it numerous times, usually with dump trucks, but never seen it. I have heard about the oil getting past the rings and not being able to shut it off, needing to stall it again before the motor is toasted.
/ 4400 running backwards #12
I have had this happen to me on two occasions that I can remember. The first time was with a Ford F7000 dump truck with a 3208 Cat engine, standard transmission, and mechanical PTO to the hydraulics. As I was dumping out a load of grass and leaves, with the body up, I tried to move the truck and hit the brake to shake the load loose. I think what happened is as the truck stalled at the same moment the dump body came forward, pushed the piston and for whatever reason after that, black smoke came out of the hood, engine running funny etc..Mechanic said it ran backwards.
Second time was with a gear drive JD1070 tractor. I wasn't paying enough attention while fertilizing a park area and ran into a tree with the front loader. Tractor bounced back and started running backwards while the tranny was in a forward gear, all the while dash light on and rough sounding engine noises. I knew right then what happened.
/ 4400 running backwards #13
Any mechanical fuel injection system with a gravity feed fuel supply will run. A neighboring dealer took in a Same Tractor a nuber of years ago. While loading he drove on to the roll back and shut the tractor off in gear to hook the winch. He then went to tighten the winch cable on the tractor and tighten the chain when the rear chain came off and the winch speed alone started the tractor and it drove over the front rack of the bed into the cab before it lost enough power to stall.
I would think that the 4400 should not have started in reverse on the pto. I do believe something is wrong with this to happen.
/ 4400 running backwards #14
QUOTE]
I just dug out the Kubota Work Shop Manual and checked. The DT, GST and HST all have a one way clutch in them to keep this from occuring.
He should call the dealer and bring it in to get it fixed before the engine is toasted.
jb
/ 4400 running backwards #15
John: That's interesting. Is the manual your looking in for the Grand L or the L4400 economy?
I know my L3400HST came with an ORC but they have eliminated that on the newer models because of some failures. I have the Kubota service bulletin that shows the new L3400 PTO clutch and the ORC feature is gone.
/ 4400 running backwards #16
I had that happen several times with my old L2500. Had it happen driving it and bogged it and also had it happen running a post hole digger.
/ 4400 running backwards #17
john_bud said:
QUOTE]
[[[I just dug out the Kubota Work Shop Manual and checked. The DT, GST and HST all have a one way clutch in them to keep this from occuring.]]]
jb
A one way clutch/ORC would not prevent this cuz they only prevent driving the engine in the forward direction.
larry
/ 4400 running backwards #18
john_bud said:
QUOTE]
jb
Hold on a minute here. The direction of the torque did not change - so an ORC wouldn't have any effect. The engine was trying to turn the winch, and the winch was resisting, slowing the engine rpm down more and more until it got to zero and then became negative. But during this the pto shaft torque did not switch direction - the orc remained positively loaded.
It's not unheard of for a winch to lift a tractor's front wheels off the ground, stalling the engine, and turning the engine backward as the front settles back down. If the engine actually fired and made power in the reverse direction, then the ORC would become unloaded and would disconnect.
/ 4400 running backwards #19
SPYDERLK said:
larry
your right. I didn't think about that.
/ 4400 running backwards #20
I suspect that all you would have to do to cause the engine to run
backwards is to stall it. You do not need to give it an external reverse
torque. That is because if one of the cyls is on its compression stroke
(likely!) there may be enough reverse torque created internally. It only
takes a partial reverse revolution for the engine to fire in the reverse
direction.
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
2017 INTERNATIONAL LF687 DAYCAB (A65643)
2017 INTERNATIONAL...
Mini Universal Concrete Bucket (A65640)
Mini Universal...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
2000 Ford F-350 Pickup Truck, VIN # 1FTSX30F3YEB26863 (A65563)
2000 Ford F-350...
