4366 hydraulics
/ 4366 hydraulics #1
derrick9415
Scobey, Mt
I have a 4366 IH and want to pull a air drill with it. Can anyone tell me what I have to do to make my hydraulics work with the hydraulic fan? Thank you.
/ 4366 hydraulics #3
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng8090
If the fan is rotated by a hyd motor, then you need a supply of fluid through a motor valve.
It depend on what you have now. Can you describe your hyd system, such as, I only have a hyd pump and 3pt, or something similar.
If you do have remotes, you plug in the hyd hoses to the remotes and bungee the valve spool open for hyd fan operation.
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
generator trailer (A61569)
generator trailer...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
