4330 leaking front axle
   / 4330 leaking front axle #11
Just don't beat it too hard or you will damage threads and such and the nut won't go back on. Yes a pickle fork is another route. Many parts stores loan tools like this for tree. Just put the nut back on a little bit so when it pops free it doesn't go flying and damage threads or you. If you have or rent/loan an air hammer that can help with a pickle fork roo, as they make air hammer attachments for them.
Good luck
   / 4330 leaking front axle #12
When you take the castle nut loose on the tie rod end turn it over and thread it back onto the tie rod stud. Do not tighten it but thread it on far enough to just barely not expose the thread. Hit the NUT with a hammer. This will most likely pop it loose and protect the threads. A pickle fork will most likely ruin the rubber seal so I would avoid that tool if at all possible.
ok, thanks for the help on the previous issue. Got off the tie rod end and got the whole steering assembly off the tractor and onto the workbench.
I pried off the bottom cap and took out the snap ring and washer below the lower bearing. Now I can not get the lower bearing out of the steering assembly. I got the inner bearing out now problem. It just popped out after taking out the snap ring and washer.
Any advice on how to get this out? I tried prying it out with two screwdrivers as recommended in another thread. I also tried hitting the lip where it comes to a stop with some emery cloth. It slides up and down very easily, just the last 1/8" before the bottom of the assembly it seems to get stopped. I might have to pick up a bearing puller/slide hammer assembly.
Any other thoughts?
Thanks
   / 4330 leaking front axle #14
With the drive flange and cover taken off (6 bolts + 2 nuts) you can use a prybar through the hole to push the gear down, pushing the bearing out. Use a rag so the prybar doesn't scratch the gear.
The lip probably just has paint on it - a file or scraper would work better.
The fun continues,
I got the lower bearing out, took off the drive flange,
Took out the snap ring about half way up, took out the axle and upper gear.
Now I am trying to get the upper and lower halves separated so that I can replace the "A" seal.
Any tips on getting those two separated? I have gotten them apart by about 1/8" so far with some pretty hard banging. Am I missing something?
I really appreciate the help so far.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59575)
2020 INTERNATIONAL...
2020 DRAGON ESP...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A56436)
Greenworks...
MASSAGE CHAIR (A58214)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
