433 3pt lift
/ 433 3pt lift #1
wincher
downeast maine
kubota L3240
Was looking at some spec's the other day and was surprised that the 3pt lift rating for the 433 and 503 were in my opion low for a machine of that size and weight. 2105lb's 24 back is good but I was thinking something more like 2800lb's. Was I wrong or are others thinking it is a little low? I won't mention the loader right now. This will probably be my next machine even if it seems like I am picking it apart.
/ 433 3pt lift #2
I noticed that (low 3 pt lift capability) on the T700. (Like 2590 lbs compared to the comparable NH which is almost 4000 lbs) and posted about in a few months back. I sent a querry into TYM via their web page but got no response yet.
/ 433 3pt lift #3
Where did you get those #'s.
I just checked TYM's website and they list the 433/503 at 2945lbs at 24" back.
But the puzzling thing is the 700cab model is 2950 at 24" back which seems low but when you look at the lift at the hitch they list the 433/503 at 3313lbs and the 700 at 4329.
Over 1000lbs more at the hitch but the same at 24"?????
/ 433 3pt lift
I like paper and got my numbers right off the 2009 spec sheet for the t433/t503 that i picked up at the dealership last weekend. I am now going to compare it to the website to see what else is off. I would like to see if anyone has any first hand info from this machine that might be able to tell us what the correct numbers are.
/ 433 3pt lift
YUP!!! these guys are starting to make me wonder. Looking at the web site for specs only made me more upset. One of the two or maybe both are completely off. These people lack the attention to detail that I was under the impression they had. The first number I put out will be web and the second my sheet. Gross hp 31.4/42.7 Pto hp 24.1/34.4 Max total flow gpm 3.4/13.4 Lift 24" 2945/2105 Lift at pins 3313/2865 Width 72.3/62.6 Weight 4188/4140. And i noticed on the website that the t503 reat pto is 580 and the spec sheet says 540:confused::confused::confused::confused:
/ 433 3pt lift
LD1 after all the work i put into finding the numbers i have been waiting for a comment.
/ 433 3pt lift #7
It's got me wondering if there is a typo on either the sheet you have or the website.
I agree that something is a little fishy. It the actual #'s are the low ones than it's not that impressive of a machine, however it the true specs are the higher ones than it's not bad.
I would try to get into contact with tym and find out what the right #'s are supposed to be. Who gave you the spec sheet? Contact them and see if they know why the #'s differ from the website.
/ 433 3pt lift #8
Hey, the more you do research on tym, the more you see they did not pay attention to detail !!!!!!!
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
10ft Fork Extensions (A64553)
10ft Fork...
(INOP) 36 BLADE DISC HARROW (A64278)
(INOP) 36 BLADE...
2026 Electric Tricycle (A64194)
2026 Electric...
2013 Chevrolet Tahoe SUV (A64557)
2013 Chevrolet...
