4320 Water Pump Remove Help needed
/ 4320 Water Pump Remove Help needed #12
Ahhhh, thank you for your reply! I did it as the previous post said, no issues.. Maybe you can answer this one too. The original tires, rear, are 13.6 x 28 R1. They are severely checked. Where I am now an R4 tire will be better suited. I know I have to change rims too. I would like more stability so I am going to put on 16.9 x 24 R4. The question is, when going from a 28" to a 24", do I have to change the fronts too? 6-16 on the front, R1 type. I am wondering this because of gearing problems? Any help would be so appreciated.
Dave
/ 4320 Water Pump Remove Help needed #13
Yes Dave. Get the R4's that go with those on the rear.
/ 4320 Water Pump Remove Help needed #14
I had a typo in the first post, I said 6-16. They are 8-16 R1 (original) I am going to call a dealer tomorrow to see the correct size in front. I see you have a 4300, tire size for that unit is 15 front and 24 back. Did you watch the Pack destroy the cowgirls? Loved it!!
TY for your reply
Dave
/ 4320 Water Pump Remove Help needed #15
I too have this problem now with my 4320. The water pump is shot. I know I have to take the radiator off, but I am having trouble. Do the two bolts on the bottom of the radiator with the rubber foot have to come off? If so, how? They just keep turning and do not loosen up at all.
Frustrated
Dave
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2015 Ford Fusion AWD Sedan (A61569)
2015 Ford Fusion...
1611 (A57192)
1611 (A57192)
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
(250) Iranch Safety Traffic Cones (A60463)
(250) Iranch...
SDlanch 20'x20' High End Carport (A60463)
SDlanch 20'x20'...
