4320 Replacement Battery Any options?
   / 4320 Replacement Battery Any options? #1
TnFarm
Tennessee
John Deere 4320
Yep, my battery is leaking. My tractor is a 2006 and noticed over the winter the corrosion. It's still under warranty but thought I would clean it up and replace the battery myself. I logged on to search about the Optima but all I can find are the threads about it being discontinued. Figured Deere would just replace with a new battery which would just leak again. Are there any options for replacement batteries that wont leak? Also has anyone had any luck with new batteries from Deere? Thanks for any help.
Hopefully my problem is solved. After neutralizing the acid and cleaning the rust, I went out and picked up an Optima Redtop. I had to make a couple of minor modifications to make things fit but it is in and ready to go.
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2007 Ford F-150 Ext Cab Pick-up Truck (A55788)
2007 Ford F-150...
24" Wain Roy Bucket (A50775)
24" Wain Roy...
35176 (A55758)
35176 (A55758)
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
Hydro Thumb Clamp (A53316)
Hydro Thumb Clamp...
