4320 Replacement Battery Any options?
   / 4320 Replacement Battery Any options? #1
TnFarm
Tennessee
John Deere 4320
Yep, my battery is leaking. My tractor is a 2006 and noticed over the winter the corrosion. It's still under warranty but thought I would clean it up and replace the battery myself. I logged on to search about the Optima but all I can find are the threads about it being discontinued. Figured Deere would just replace with a new battery which would just leak again. Are there any options for replacement batteries that wont leak? Also has anyone had any luck with new batteries from Deere? Thanks for any help.
Hopefully my problem is solved. After neutralizing the acid and cleaning the rust, I went out and picked up an Optima Redtop. I had to make a couple of minor modifications to make things fit but it is in and ready to go.
Motorhome (A55853)
Motorhome (A55853)
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A55787)
2020 Caterpillar...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
ITEM LOCATION (A53084)
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
