4320 error code help
/ 4320 error code help #2
dwmaster,
Error code 14 is something you need to call your dealer about - unless you are a tech, it is not something you will be able to rectify yourself at home...
The code is telling you that there is either an open circuit, or a shorted circuit. Your dealer would be able to verify which problem with a volt meter and a copy of the schematic. Basically, the hydraulic pump coils for the eHydro transmission either have excessive resistance or no resistance - either problem would cause a lack of drive.
Your dealer should be able to take care of this for you without a problem. Hope I was of some help!
T:D hanks the dealer is going to fix it on Monday.
/ 4320 error code help #4
dwmaster,
Just wondering how everything worked out with your tractor???
Unfortunatly it first happen on Saturday. The dealer could not do anything without help from etech so we had to wait until Monday morning. They spent Monday checking the system over with etech. They determined today I need a new controller. It is located under the dash. It will be here in the morning. The good thing about John Deere is most parts show up the next morning. So I should be going in the morning.
