4310 willnot start
/ 4310 willnot start #1
dpoole
marietta s.c.
jd 4310 , jd 750
i have a 4310 , I used it last week it worked fine , no problems , I parked it , went back to start it today, it turns over good but willnot start. HELP
/ 4310 willnot start #2
Does it try to start, any smoke or cough like it's getting fuel?
If not it's a fuel problem.
Check the fuel shut off, make sure you have flow from the tank, filter etc.
/ 4310 willnot start #3
If it's turning over then the problem is most likely a lack of fuel. Look at the circuit diagrams if it has an electric solenoid fuel shut off. Turn the key and see if it clicks open. If it doesn't, then there may be a switch that isn't closing in the safety interlock system.
If it does click open, you may have an obstruction in the fuel delivery to the injection pump. If it has a lift pump, is it turning on when you turn the key. Is there adequate fuel coming from the tank to the fuel filter and from the fuel filter to injection pump. You could have anything from a clogged fuel tank strainer to a plugged fuel filter. A fuel line can be pinched, etc. Make sure the fuel line connection are snug so you can't suck air.
If you change the filter (plugged filters are probably the most common cause of no starts), remember you have to get all the air out the fuel filter and lines so get your ownersmanual and see it's recommendations for bleeding the fuel delivery system. If you don't have one,get one. In the mean time get back here and i'll get you some general instructions.
thanks for the suggestions , I got a wireing diagrahm off the net. I checked the shut off solenoid there wasd no click when switch was turned on , i removed solenoid and the plunger was stuck after pushing it in several times i reconnected it to the wireing connection , turned switch on and it worked did this several times then put it back on tractor and it has worked so far , also it was giving me a fault code , something to do with the fuel circuit , this code also cleared up. crossing my fingers;; thanks again
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
Industrias America 84" Skidsteer Quick Attach Bucket (A66408)
Industrias America...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A65643)
2012 WESTERNSTAR...
2016 John Deere 6155R (A64119)
2016 John Deere...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
Mini Universal Trailer Mover (A65640)
Mini Universal...
