4310 used value?
/ 4310 used value? #1
chickenman
What is the value of a 2004 jd 4310 hydro with cruise upgrade, 430 fel, 1400 hours in excellent shape and a 2004 millcreek 75 manure spreader hardly used , excellent shape
/ 4310 used value? #2
You need to separate them to figure the value of each. Most will not have a need for a manure spreader but just find that one person that just might need it.
1400 is a bit more hours than a home owner would have on a privately used unit. So obviously this was used in a business or some type of operation.
If you go to tractorhouse you can look to see what comparable units are being priced at. Lots of variables here. Is it clean? Stored indoors or out? Maintenance at regular intervals? etc...
I think there have been threads which try to put a $ amount per hour used and if I remember right it was between $5 and $10 per hour up to a point in which the intrinsic value held up the price over the devaluation of hours.
I would guess the tractor is worth around $10K to $13K depending on the shape.
/ 4310 used value? #3
2014 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2014 FORD F150...
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
WACKER NEUSON LTN6L LIGHT PLANT/ GENERATOR (A65056)
WACKER NEUSON...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
