4310 tilt stearing wheel
   / 4310 tilt stearing wheel #1
chickenman
my tilt stearing wheel has gotten all cratchity.
has anyone else had this problem and how was it solved?
   / 4310 tilt stearing wheel #2
What do you mean by cratchity? How long have you had your machine?
Any idea what happened to the other site?
it sticks and is difficult to adjust
and no i dont
   / 4310 tilt stearing wheel #4
My 4710 had a real sticky tilt when i first got it. I had the dealer lube it when it was in for service, and now its perfect. I would think pulling a cover off and spraying lube in there would fix it.
   / 4310 tilt stearing wheel #5
Hi
My 4310 had the tilt steering stuck and I sprayed it with WD40 and it has been fine ever since.
Richard
   / 4310 tilt stearing wheel #6
My 4310 was like that and eventually got stuck in the down position. I took it in and there was a service bulletin about this problem. They fixed it and it has been fine for about 70 hours. It stuck at 40.
What other site?
   / 4310 tilt stearing wheel #7
My 4410 had that problem from the get go. There was a service advisory on this. They put new parts in it and the tilt works OK now but there is still a lot of play in the steering wheel itself.
   / 4310 tilt stearing wheel #8
Now I'm back to thinking you are talking about the steering wheel, and not play in the tilt. /forums/images/graemlins/confused.gif
I may catch up, but I'm a bit slow. /forums/images/graemlins/wink.gif
i got the parts under warranty and installed them myself
the tilt mechanism has to be the chintziest thing ive seen in a long time, fragile dicast metal
i don't pull myself up by the wheel anymore
it really is delicate, the service manager said that they have replaced hundreds of them
202474 (A54757)
202474 (A54757)
Nalco 400G Rectangular Tank W/ 44" Stainless Flowmeter 5/8"Tube G00927 (A59225)
Nalco 400G...
15' WICK BAR W/ ALUMINUM MOUNTS (A52708)
15' WICK BAR W/...
(INOP )JOHN DEERE RIDING MOWER (A58374)
(INOP )JOHN DEERE...
OPENATS ROTARY TILLER (A52708)
OPENATS ROTARY...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
