4310 Rear Scv & power beyond
/ 4310 Rear Scv & power beyond #1
DIESELbowhunter
PA
John Deere
Hey guys,
Are there still kits available to add a rear SCV and Power Beyond to a 4310 tractor? I've done some research and haven't really found a definite answer.
/ 4310 Rear Scv & power beyond #2
A John Deere dealer will be able to find out if other dealers have kit's in stock.
Here's what I would do. I would make my own kits. The rear SCV kit comprises of a lever and hoses/brackets etc. I would buy the lever from Deere and make up the rest myself. The third valve is already on the tractor in the same block as the joy stick controls. All you need to do is remove the plugs for the hydraulic lines and match them up with appropriate fittings on the hoses. Add female couplers the the other end of the hose and mount them on the tractor. JD used to charge $700 CAD for the kit. Way overpriced for what you get.
At some point in time I will make my own Power Beyond kit. I asked on this forum and someone sent me the installation instructions for the kit. That together with the service and parts manuals gives me enough info to make up my own kit.
/ 4310 Rear Scv & power beyond #3
Hey guys,
You can still get a third scv and maybe a power beyond kit for your tractor. SCV kit LVB25084 is around $330 and power beyond kit LVB25085 doesn’t show a price so idk about that one. You would have to call dealer
/ 4310 Rear Scv & power beyond #4
I found a NOS on eBay for $130 recently. It was missing the console (black piece of plastic that holds the handle) which is reasonably priced through Deere.
The fittings on the bottom of the scv are metric orb, so depending on your hydraulic shop it might be special order if you go custom.
/ 4310 Rear Scv & power beyond #6
texasranger, I am making my own 3rd scv 'kit' so to speak, for my 4310, but before i take off the fender, i want to have all the parts ready. You mentioned fittings needed on bottom of scv are metric orb, would you know the 'size' of the metric? Anyone else feel free to chime in if you know the answer. Thanks
/ 4310 Rear Scv & power beyond #7
Both are available at Green Farm Parts. I just put the power beyond on a 4210. and looked at the 3rd SCV, but don't really have the need for it now. The 3rd runs $325 and the PB runs $350 I think.
/ 4310 Rear Scv & power beyond #8
I know they are for available, but as I stated I am making my own, and need to know the size fittings into the bottom of the scv. JD parts just lists it as Adapter Fitting "STUD STRAIGHT (SDS), ORFS" but does not include the size. Does anyone know the size of this fitting?
/ 4310 Rear Scv & power beyond #9
I'll look this weekend and get back to you with measurements
/ 4310 Rear Scv & power beyond #10
I have my valve out now. I tried to plug the in and out ports, and the SAE o-ring fittings I have are not the same thread. I think the valve is metric. I did not try the bottom ports.
/ 4310 Rear Scv & power beyond #11
So the part number is: 38H5003
After using the Googler, I found this link on a very helpful forum.
http://www.tractorbynet.com/forums/john-deere-owning-operating/333234-qd-couplings-jd-5083e-2.html
From link:
Thanks.
I found out the thread on the valve port is M18x1.5, adapter for it: JD part# 38H5003
I think it is M18x1.5 Metric Male to #8 SAE/ORB Female (or M18x1.5 to 13/16-16 ORFS, #10 SAE/ORB?? Not sure)
It is strange why they installed metric Quick disconnects and run a hose with metric on one end, SAE on the other and adapter SAE back to metric.
Here are JD part numbers for anyone who wants to change the QDs to SAE:
RE60527 - SVC with M18x1.5 ports (plugs are RE46685)
T77857 O-ring for between the hose and the nipple (38H5003)
51M7043 O-ring for between the nipple and the valve
38H5003 - nipple M18x1.5 to #8 SAE/ORB or #10 SAE/ORB
You can install the discounthose adapter right into the valve (instead of 38H5003 above):
9335-18-08 | M18x1.5 Metric Male x #8 SAE/ORB Female
then you can do whatever hose, QD you want.
I think they should have installed #10 SAE/ORB everywhere, but that would be too easy to replace JD parts :) Evil JD!!!
/ 4310 Rear Scv & power beyond #12
Re: 4310 Rear Scv & power beyond
The power beyond port on the loader valve is M22x1.5 ORB. I don't know what the 3rd scv ports are off the top of my head, I'll try measuring the adapters in the kit I bought this weekend.
Edit: now you have me second guessing my memory. I'll check that port too.
/ 4310 Rear Scv & power beyond #13
You are probably correct, the PB port and input ports are the same and bigger than the bottom output ports.
If the poster want to add PB cheap, I would pull off the steel tube from the tractor, and take it to a hydraulic shop and have them cut out a section add JIC female nuts, and flare the end pieces. Then you can use JIC fittings and hoses with quick disconnects to do it.
/ 4310 Rear Scv & power beyond #14
Mike
I think you can delete the duplicate posts.. if you want to...
I tried, said I need to be an administrator. Sometimes at work, it is slow and I accidentally click post twice, and it actuals post it twice.
I just got it to work. Thanks,
/ 4310 Rear Scv & power beyond #15
Mike this is how i planned the pby, pretty simple mod, but for my scv you did find a post that hits the '38H5003' on the head, thanks! I spent hours looking through google, you found the needle in the haystack! What's funny about jd parts web site is they give 9 specifications just for the PIN that connects the 3rd scv valve to handle, but cannot even list the size of the adapter!!! Texasranger, if you would be so kind, just to verify the port size on *4x10 3 valve scv bottom ports* (assuming 4x00 you have is same) this week end would be great. Thanks Guys!
Mike I missed a post on page 1, you say your valve is out now, could you measure yours? If i can I would like to order this week to receive next. If I wait on texas ranger I'd be another week from ordering on monday. Thanks
/ 4310 Rear Scv & power beyond #16
I went to a hydraulic shop this week. I didn't but any, but he said those are 18mm and the larger are 22. I bought a 22mm fitting and it fit, so
I assume he is right about the 18mm, but I didn't try it. I can try to measure later, but I am Farley confident it is right. The fittings are about $15 at a parker store to a 1/2: NPT female. Didn't but any, but they said they had them.
/ 4310 Rear Scv & power beyond #17
Your post with the link, and quotes, plus a guy pm me 18x1.5 , and YOUR guy at hydro shop today says 18, today at JD parts counter man says 18mm, so I will go ahead with order. I picked up the hoses just couple hours ago, and couple other sleeve and bushings, clevis, etc. Great project since the weather just took a bad turn to cold, cold, cold. I feel like working indoors. Thanks for all the help, and I will post the pics of the install and finished project.
/ 4310 Rear Scv & power beyond #18
Can you post pictures of what you do for the handle? And dimensions or a drawing would be good. I might want to do the 3rd SCV someday. The handle seems to be the biggest part of it all.
/ 4310 Rear Scv & power beyond #19
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2005 Ford F-450 Crane Service Truck (A66736)
2005 Ford F-450...
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
2019 CATERPILLAR 299D2 SKID STEER (A65056)
2019 CATERPILLAR...
10ft Fork Extensions (A66734)
10ft Fork...
