4310 Front axle
/ 4310 Front axle #1
Hookblock
WI
JD 4310
I had the seal go out on the rt. front hub. I have the manual and thought, I can do this my self. Everything went well, the seal was 25.00 and some oil. To press it apart I used a gear puller. To put it back together just some heat to slide everything back together.
/ 4310 Front axle #2
Excellent job! Glad to see those FSM's get put to good use!;)
/ 4310 Front axle #3
Good work!
And the best part - you were generous enough to share the details of your project with us!! :)
Thanks.
AKfish
/ 4310 Front axle #4
Thanks for the pics.
I have never seen this assembly taken apart.
How many hours do you have on the machine? Any cause for the seal leaking?
/ 4310 Front axle #5
Yup, good to know it's home doable if the need ever arises, How bad a leak was it? and I'm curious about the hours as well, mine has about 350 hrs.
JB.
/ 4310 Front axle
Thanks guys, The leak was to the point of leaving a small puddle on the floor. The cause?... I was pushing a lot of brush, and I think it might have gotten into the seal. I have about 580 hours on it. I wish I would have taken more step by step pictures. Everyone on this site has helped me so much, it's nice to give back :)
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2004 POLAR TANK CRUDE PUP TRAILER (A67714)
2004 POLAR TANK...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2018 Ram 1500 4x4...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
1981 LINK BELT HSP 8028 (A67714)
1981 LINK BELT HSP...
